Microsoft Windows [Version 10.0.15063]
(c) Корпорация Майкрософт (Microsoft Corporation), 2017. Все права защищены.
C:\Users\Михалыч>cd C:\
C:\>java -jar ast.jar
Test Tool Started
Following usable ports available in your system.
Pick the one where Arduino board is connected:
0) COM9
1) Quit
Please enter from 0 to 0 or 1 to exit...
> 0
Ok, selected port: COM9
Proceeding with the tests...
Opening port COM9... OK
Configuring port with 38400,8,N,1... OK
Sending Status Check command... OK
Waiting for responce... OK
Checking if Arduino already initialized... NO
Sending Init Board command... OK
Arduino board initiated: true
Pressure sensor detected: true
Sending Check Parasite Powered probes command... OK
Parasite powered devices detected: no
Sending Start Temperature Polling command (2 sec interval)... OK
Waiting for 6 sec to allow Temperature reports to arrive...
Seq [1] for device 28FF1CA3861605FE temp: 20.9375
Seq [1] for device 28FFD5B786160519 temp: 19.75
Seq [1] for device 28FF3D9D86160596 temp: 20.3125
Seq [2] for device 28FF1CA3861605FE temp: 20.9375
Seq [2] for device 28FFD5B786160519 temp: 19.8125
Seq [2] for device 28FF3D9D86160596 temp: 20.3125
Seq [3] for device 28FF1CA3861605FE temp: 20.9375
Seq [3] for device 28FFD5B786160519 temp: 19.8125
Seq [3] for device 28FF3D9D86160596 temp: 20.3125
Sending Change Temperature Polling Params command (1 sec interval)... OK
Seq [4] for device 28FF1CA3861605FE temp: 20.9375
Seq [4] for device 28FFD5B786160519 temp: 19.75
Seq [4] for device 28FF3D9D86160596 temp: 20.3125
Seq [5] for device 28FF1CA3861605FE temp: 20.9375
Seq [5] for device 28FFD5B786160519 temp: 19.8125
Seq [5] for device 28FF3D9D86160596 temp: 20.3125
Seq [6] for device 28FF1CA3861605FE temp: 21.0
Seq [6] for device 28FFD5B786160519 temp: 19.8125
Seq [6] for device 28FF3D9D86160596 temp: 20.3125
Seq [7] for device 28FF1CA3861605FE temp: 21.0
Seq [7] for device 28FFD5B786160519 temp: 19.8125
Seq [7] for device 28FF3D9D86160596 temp: 20.375
Seq [8] for device 28FF1CA3861605FE temp: 21.0
Seq [8] for device 28FFD5B786160519 temp: 19.8125
Seq [8] for device 28FF3D9D86160596 temp: 20.375
Seq [9] for device 28FF1CA3861605FE temp: 21.0
Seq [9] for device 28FFD5B786160519 temp: 19.8125
Seq [9] for device 28FF3D9D86160596 temp: 20.375
Sending Change Temperature Polling Params command (0.5 sec interval)... OK
Seq [10] for device 28FF1CA3861605FE temp: 21.0
Seq [10] for device 28FFD5B786160519 temp: 19.8125
Seq [10] for device 28FF3D9D86160596 temp: 20.375
Seq [11] for device 28FF1CA3861605FE temp: 21.0
Seq [11] for device 28FFD5B786160519 temp: 19.8125
Seq [11] for device 28FF3D9D86160596 temp: 20.375
Seq [12] for device 28FF1CA3861605FE temp: 21.0
Seq [12] for device 28FFD5B786160519 temp: 19.8125
Seq [12] for device 28FF3D9D86160596 temp: 20.375
Seq [13] for device 28FF1CA3861605FE temp: 21.0
Seq [13] for device 28FFD5B786160519 temp: 19.875
Seq [13] for device 28FF3D9D86160596 temp: 20.375
Seq [14] for device 28FF1CA3861605FE temp: 21.0
Seq [14] for device 28FFD5B786160519 temp: 19.875
Seq [14] for device 28FF3D9D86160596 temp: 20.375
Seq [15] for device 28FF1CA3861605FE temp: 21.0
Seq [15] for device 28FFD5B786160519 temp: 19.875
Seq [15] for device 28FF3D9D86160596 temp: 20.375
Seq [16] for device 28FF1CA3861605FE temp: 21.0
Seq [16] for device 28FFD5B786160519 temp: 19.875
Seq [16] for device 28FF3D9D86160596 temp: 20.375
Seq [17] for device 28FF1CA3861605FE temp: 21.0
Seq [17] for device 28FFD5B786160519 temp: 19.875
Seq [17] for device 28FF3D9D86160596 temp: 20.375
Seq [18] for device 28FF1CA3861605FE temp: 21.0
Seq [18] for device 28FFD5B786160519 temp: 19.875
Seq [18] for device 28FF3D9D86160596 temp: 20.4375
Sending Board Shut Down command... OK
Shutdown of device successful!
Test Tool Exit - Port closed.
Это отчёт теста. Запустил после него тма. Заставка Алкодистиллерс и всё пропадает. Прога не запускается. Всё как в прошлый раз. Тест, я понимаю, железо прошло на ура.
Пробовал запускать из командной строки. Результат тот же.
РК медь 42*1500 мм насадка периодическая спиральная нержавейка нагрев 4500 Вт отбор 1500 Вт Деф наклонный 6мм*3м
